My xtreme 3 won't charge
I brought a jbl xtreme 3 2 weeks ago the battery has died and I can't get it to charge. I plug it in and it just turns back off
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hello Katie, plug it into the computer , as if the computer would be charging it , open your options for external discs, find the device , go into the settings if possible, or if not possible , eject the device with options from the computer. then it should work, unless the battery is dislodged, then it’s a lot more complicated.
이 답변이 도움이 되었나요?
My boombox is completely dead and I can't get it to charge. I thought they when it was dead just plug it in
이 답변이 도움이 되었나요?
I found the issue on my end. Check the charging board to see if the ribbon cable is connected or if it has a break. If the ribbon cable is not connected, the box won't have charging logic and won't be able to check the battery status. If that doesn't solve the problem, the battery is probably defective.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 11
지난 30일: 43
전체 시간: 1,405
