주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio fx-9750GII는 Casio에서 판매하는 그래프 계산기입니다. 계산기 앞면 오른쪽 상단 모서리에 있는 "fx-9750GII"라는 제목을 통해 기기를 식별할 수 있습니다.
Why are my function keys not working properly?
My function keys are not working properly.
In Run-Math program, if I press F1, nothing happens. If I press F2, it opens a list of options in the botton (LIST, MAT, CPLX, CALC, STAT). If I press F3 it opens another list of options (V-WIN, FACT, STAT, GRPH, DYNA). If I press F4, it acts as going into the previous screen (For example, If I am in Run-math and I was in the menu before, it goes to the menu and if I press it again it goes back to the Run-math). F5 acts as the Left arrow key in text editors. F6 acts as moving back a line (selecting the previous line).
Every other button work as intended.
I tried to reset the system through the menu, but since the function keys aren’t working properly, I can’t select the reset option. I’ve also tried the small button on the back of the calculator, but it doesn’t do much.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
Hello Ricardo, did you maybe had a spill onto the keyboard?, also if the unit is old, ( i don’t know how old) some buttons might stop working , like buttons of tv remotes, it might be worth it to open the whole thing to have a look if its dirty or worn out . if its worn out, there is a conductive glue available from specialised electronic shops, just cover the tip of the missing carbon rubber with a very thin layer of the conductive glue , wait for it to dry, reassemble. also while you have it open, maybe then you can check if bridging corresponding pad of the reset option would do anything. good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try to redownload the program. I had the same issues and it helped me. It gave me a lot of problems because I used it for education. Fortunately, this site https://plainmath.net/textbooks/ saves me from failing lessons. But maybe someone has other more smart suggestions?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricardo OKay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 32
전체 시간: 1,513
