주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
마더보드 및 CPU 수리 안내서 및 지원.
질문 마감됨
Single out the hardware error
Has anyone information for determining which component is giving trouble?
Situation: PC shuts down and does not power up anymore. Power LED alluminated but all that is active is the fan. How can I confirm that the power button is giving trouble?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Depending on your specific hardware. I would start off with a multimeter and see what the power supplies does. I have had PC's that did this with bad CPU's , CMOS that needed to be cleared as well as as bad Caps and numerous other errors.
의
Which pc? Model no. ?
의
댓글 달기
답변 2개
선택된 해법
If your computer is running slower than usual, randomly freezes or restarts, or refuses to boot, see the Motherboard Has a Faulty Capacitor problem page for capacitor troubleshooting help.
Here is a link to a troubleshooting process to help determine your problem. If that doesn't clear your problem please google "PC shuts down and does not power up" for further links that may be a help to you.
http://pcsupport.about.com/od/findbysymp...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I have replaced capacitors on several boards to bring them back to life. If any of the capacitors on the board are puffed up on top or are leaking; then that's the problem.
Just read the side of the capacitor to get the type and ohms. I get mine from mcm electronics. They carry a wide selection and good prices.
You un-solder the old one. Note the orientation before removing, that determines the +\- side. Solder in the new one.
That should do it. Most times there was more than one that popped. Check the board carefully. Good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 22
전체 시간: 2,425
