주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 1월에 출시되었으며, 모델 번호 BDP-S3700으로 식별 가능함
Issues with external speakers
I’m stumped. I have a TCL 5-Series QLED 4K UHD Smart Google TV (Model: 55S54), with a Sony BDP-S3700 blu-ray player in one HDMI port and a set of external Panasonic speakers (Panasonic SC-HTB20) hooked up in another HDMI port. They work completely fine with the TV itself, though I have noticed they automatically stop producing sound when I’ve left the TV sitting without actively watching anything. When I try to use them with my blu-ray player, the speakers will work for about two minutes, and then they just quit working. They still appear to be on, and the disc will continue playing, but I’m not getting any sound. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
The user manual is not that explicit as it doesn't give all the options that are there but maybe check the audio out delay setting in Settings > Audio.
According to the manual this corrects timing mismatches between the audio and video tracks. This option is only available when Digital audio out is set to PCM
Also check if there are any advanced options for the HDMI connections.
Does the TV have a designated HDMI-ARC port? Maybe swap the HDMI cables from the speaker and the player over and check if this resolves the problem. Turn off the power to all devices before unplugging/plugging HDMI cables as you can damage the HDMI controllers by "hot swapping".
Have you checked if the TV firmware (software) is up to date just to see if there are any system updates. Go to Settings > System > About.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Unfortunately, I think this is just a lost cause. Now none of it is working.
의 공유
댓글 달기
답변을 추가하세요
Noelle Bye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 32
전체 시간: 444
