주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Notebook 15-ba018ds는 Windows 10 운영 체제가 탑재된 터치 스크린 기능 노트북입니다. 닫았을 때의 크기는 16 x 10 x 3인치이며 무게는 4.83lbs(약 2.19kg)입니다.
Why are these voltage differences?
Hello everyone.
Please, I would like your help in order to help me understand what and why are these small voltage differences on laptop batteries when going for new buy for replacement.
laptop model is:HP Pavilion 15db1027nv
HP original battery is: HT03XL (or REPLACE WITH HP SPARE L11119-855)
On original battery also:
11.55V
41.7Wh
3470mAh
Just exactly like here:
https://www.amazon.com/Compatible-L11421...
But, on many selling sites, the elements (Volts, Wh, mAh) differ a little, just like here:
https://www.aliexpress.com/item/10050041...
Here, Voltage is not 11.55 but 11.40.
a. On replacement, shouldn't voltage be EXACTLY the same? If second battery, with 11.40V is bought and installed, what are the coincidences? Could it cause any damages?
b. What and why batteries are produced even with this small differences?
Thank you for your time!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@johnyb98 shouldn't voltage be EXACTLY the same? No. The voltage listed is the nominal voltage and does not take the typical end-of-discharge and max charge voltage and other variable like ambient temperature etc. into consideration. That is why variations are absolutely normal. You do not know the state of the new battery vs. the old battery. Could it cause any damages? Not it it is within the parameter of your device (don't use a 12V battery on a 5V device;-). remember that even batteries are now smart devices. There are circuits that control over and under voltage (within reason) and the 2% difference in your battery most certainly will not do any harm to your system. Remember, you do not know the charge state of your battery. You are good to use that battery without any sequalae to your computer.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you very much for your answer and these precious technical information!! You totally helped and covered on my questions.
의 공유
댓글 달기
답변을 추가하세요
John Eidert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 29
전체 시간: 391
