Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
좋은 질문입니까?
좋은 질문입니까?
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
이 답변이 도움이 되었나요?
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 444
댓글 2개
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
James Wildgust, Sr. 의
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
bill 의
