주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Battery Replacement iPod Nano 4th Gen
The battery backup is only 15 minutes. Where can I find replacement battery (original or third party)?
It’s a 350mah 3.7V Li-Po Battery (MPN:616-0407).
Can any battery with these specifications work for my iPod or I have to check its dimensions?
I live in India.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Thanks OldTurkey for the comment. I am able to find numerous options in my country when I search for Li-Po 350mah 3.7v battery but am not sure every one of them will be compatible with iPod. So my question is do most Li-Po batteries with 350 mah 3.7v work with iPod or I need to check the dimensions as well? Unfortunately, I am not able to find specific battery (genuine or 3rd party) 616-0407 in India so was thinking of ordering generic ones with similar capacity and voltage.
댓글 달기
답변 1개
가장 유용한 답변
Swati Jain the APN numbers is correct at 616-0407 You do not need the dimensions if you order by that number. Apparently a 616-0467 will fit as well. Since you are not in the USA iFixit sadly enough cannot send those batteries overseas. That means you would have to find a vendor that does. Ali express has those batteries as well and should ship to India. We can of course not speak for the quality etc. of those batteries.
iPod Nano 4th Generation Battery Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Swati Jain yes, the physical dimension of the battery for this model iPad is crucial. There is not much room for any variations. It is a tight fit at the best of times.
댓글 달기
답변을 추가하세요
Swati Jain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 535
