주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GE 전자레인지 모델 JVM1650BB 007은 외부 배기 기능을 갖춘 1.6세제곱피트 용량의 1000와트 전자레인지입니다.
New line fuse needed?
My microwave use ceramic line fuse 20A 250V
Can I use any ceramic fuse if rating is the same even if it is not a line fuse or do I need to use a line fuse?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi
Do you know for sure it’s the fuse?
To confirm it I would get a multi metre in continuity mode and check for a beep:-)
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hi @k1love
As long as the rating is the same i.e. same volts and amps, that it is a ceramic fuse and that it fits securely into the fuse holder, it will be OK .
If you want the manufacturer's recommended replacement fuse, search online for WB27X10928 to find suppliers of the fuse that suits you best.
There is always a reason why a fuse has blown so perhaps get 2 or 3 just in case you haven't found the reason why the fuse blew as it may happen again soon after you replace it.
Be safety aware when working in a microwave oven. The HV capacitor in the oven can store >6000V DC for months even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the microwave's cover has been removed and before commencing any further work inside the oven.
Protects the microwave from electrical damage by breaking the circuit during power surges or faults. 이미지
제품
GE Microwave Fuse - WB27X10928
$18.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
KLove 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 454
