주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Game Boy Pocket은 1996년 Nintendo에서 출시되었습니다. Game Boy 라인업의 두 번째 기기입니다.
What else can I do?
Hi there, I have been trying to fix this Gameboy Pocket for a while now. I have cleaned everything on the board with rubbing alcohol, reflowed all the pins next to the chips, cleaned off some battery corrosion on the pins of these really tiny chips near the battery terminals, and replaced the battery contacts. But for some reason, the Gameboy will get power and a black bar will appear, 20% of the time, but no further. Won't play a game. I have a multimeter but need to learn how to use it. Any suggestions? This is my first project, I really want to make this work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@pocketmonster this" cleaned off some battery corrosion on the pins of these really tiny chips" will warrant some closer inspection. You did not tell us how you cleaned your board etc. Those are important steps since corrosion could be killing your components or traces and be the cause for this. You do want to go ahead and post some good pictures of your board and the corrosion etc. with your question. That way we can see what you see. Ultimately, after a proper cleaning you want to download the schematics from places like this and start checking the components etc.
Adding images to an existing question - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Coleman Smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 19
전체 시간: 270
