주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creality에서 제작한 Ender 3 3D 프린터의 업그레이드 버전인 Creality Ender 3 Pro에 대한 수리 정보입니다. 2018년 9월에 출시되었습니다. 모델 번호: Ender 3 Pro.
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 10개:
was the printer bumped at all?
의
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
의
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
의
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
의
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
의
댓글 5개 더보기
댓글 달기
답변 1개
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frank Lovash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 34
전체 시간: 4,246
