주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 4월에 출시된 LG의 G 시리즈 플래그십 Android 스마트폰입니다.
Re-Assembly Adhesive Advice
I am looking to replace the battery in my LG G8 ThinQ. I've found the guide, and the replacement battery itself. The one step I'm having difficulty finding advice on is how to re-adhere everything once the battery has been replaced. Any guidance or advice would be MUCH appreciated!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I guess my main question is what adhesive material should I use to hold everything together again.
댓글 달기
답변 1개
가장 유용한 답변
put a squiggle down like a small one just enough to hold like b,t,e,a,c,d6000,7000 adhesive so Ya that Ezzy just makes sure u would be able to get it out too if needed to replace the battery again u know how batteries are and Carful of the board and Ribin cables it is glue u know
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
super glue can work too but it's not really meant for it can melt certain plastic screens and battery's so do some research
I'm not sure I follow. Put a squiggle down?
small amount but not too much
I'm looking to do this for someone and I'm not sure what the b,t,e,a,c stand for as far as options to use.
@andrewwith31847 I see what you mean; a little more leaning toward "proper" english might have helped in this case.
Anyway, I believe they're trying to tell you that pretty much any of the common glues will work; combine the letter with either of the numbers - e.g., b6000, t7000, e6000, c7000, etc.
If you look up screen glue on AliExpress, it appears B7000 and T7000 are currently popular choices.
I would actually suggest looking for a sheet of precut adhesive first, though. If available, it will be an exact fit and will avoid any possibility of problems due to glue getting in places it shouldn't be.
댓글 달기
답변을 추가하세요
Ryan J Carney 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 645
