주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SanDisk microSD 카드는 TransFlash/microSD 형식의 저장 장치/매체입니다. 표준 모델은 최대 2GB까지 다양한 용량으로 제공됩니다. 2001년 10월에 출시되었습니다.
What information should I put?
I'm trying to see all the past photos and videos of my SanDisk MicroSD Card 2GB trough USB in Windows 10, but it says I need to "Format" it first to use it, but I am confused on what setting I should insert, (Specially the "Volume" ).
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Do not format the card!
If you do a full format on the SD Card, you will lose all your files (photos and videos) that are stored on the card. They will be erased.
If you do a quick format, the file address table on the card will be erased, which is essentially the same thing as you won't be able to retrieve files, at least not easily.
If Win 10 shows that the card needs to be formatted it can't read the card so either the card is faulty or corrupted or the USB SD Card reader may have a problem. Can you read other SD Cards OK using the card reader?
Where was the card previously inserted? If it was a camera can you view the files from the card in the camera at all?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Omali Y. Martínez Rivera 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 351
