How I charge f to c
How I change Fahrenheit to Celsius
좋은 질문입니까?
Here's how to change the passenger compartment temperature display between Fahrenheit and Celsius, if this is what you meant.
To switch the temperature mode between Centigrade to Fahrenheit:
While pressing the MODE button, press the DUAL button for 3 seconds or more.
The display will change from Centigrade to Fahrenheit, or from Fahrenheit to Centigrade
이 답변이 도움이 되었나요?
Do you know if this method also works for Santa Fe 2013/2018?
Hi @erolmacc
On the heater/air con controls press and hold the Off button and then whilst still holding the Off button press the Auto button for >3 seconds and then release. This will change the display from Fahrenheit to Celsius and vise versa.
This is for a Sante Fe 2015
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 45
전체 시간: 6,453
댓글 2개
Hi @baderalbadry
More information is required to help you.
Which temperature indicator do you wish to change in the car?
To convert F° to C° you can always use the formula (F° - 32) x 5/9 = C°
jayeff 의
Hi jayff
Yes in my car sonata 1014
Bader 의
