주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
구글의 3세대 픽셀 브랜드 스마트폰이자 최초의 '홈 화면' 스마트폰입니다. 6.3인치 QHD+ OLED 디스플레이와 64GB 또는 128GB 저장 용량을 제공합니다. 거의 흰색, 저스트 블랙 또는 핑크색으로 제공됩니다.
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
의 공유
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
의 공유
Thanks, going with the electrical tape for this!
의 공유
@Justin O
That great:-)
의 공유
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
의 공유
댓글 2개 더보기
댓글 달기
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Justin O 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 840
