주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creality에서 제작한 Ender 3 3D 프린터의 업그레이드 버전인 Creality Ender 3 Pro에 대한 수리 정보입니다. 2018년 9월에 출시되었습니다. 모델 번호: Ender 3 Pro.
Motors are no longer functioning
My 3D printer is no longer moving and makes a loud clunk noise when it attempts to move, this happened after I attempted to download south leveling firmware from the creality website, I’ve tried flashing it, and it no longer flashes, I’ve attempted to do all of the fixes presented, like the old firmware on a new SD card in plugging it and plugging it back in, but nothings working. How do I fix this issue
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sounds like a corrupted or wrong firmware . First you have do determine if your Ender came with the new 4.x.x boards( you have to take the cover off and you will see it printed on the board) which are now 32bit with a bootloader pre-installed . If it does , then you can use the SD card to flash the firmware. It may fail few times but eventually it will flash. Re-formatting, trying different SD cards and different storage sizes are few things you can try. However, if you have an original Ender with 1.x.x boards then the flashing process is bit more complicated because these boards are only 8 bit with no bootloader installed. If you search for Teaching tech, Thomas Sanladerer , or CHEP on YouTube. They have plenty of detail and step by step videos for the Ender 3 and the flashing process. Good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Larc McGee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 585
