주요 콘텐츠로 건너뛰기
Charges but no power
I have a 2ds I have recently turned on and worked perfectly I stopped using it for a few months and now it doesn’t turn on it it starts to charge but then stops and sometimes does charge but when it does charge I get no power when I try and turn it on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
firstly, does the 2DS power on when plugged into power?
If it is working on power but not when unpluged you likely have a bad battery. you can take this out and measure it with a multi meter to see how much charge it is holding, batteries in DS's and other electronic devices can go "low" meaning they want charge properly and never store enough power without being charged by an external charging station.
If its dead/dead, then refer to some of the troubleshooting guides on this website.
Nintendo 2DS
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
It doesn’t work when plugged it I removed the battery plugged it back in I unplugged and reconnected the ribbon cables in the back and nothing works it shows that it charges then the light turns off
so its possible you are dealing with a cicuitry issue, again refer to some of the troubleshooting this website has, i have not encountered this issue myself sorry
It’s Alright I will try and figure it out threw the trouble shooting thank you though
댓글 달기
답변을 추가하세요
Colin flannery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 94
