주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
20 질문 전체 보기
Loose USB-C Ports 2017 MacBook Pro
I have a mid 2017 Macbook Pro and all of my USB-C ports are loose (do not click when cable is inserted), have been to my local Microcenter and they say that I would have to replace the entire top case, and cost around $180 plus ~4 week wait time. So, I am wondering if there is any other way to fix this issue.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Well, I'm not sure why they told you that! The case is not where the connectors are. Here's the needed part MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board now the grounding clips are springs which sit in slots as you can see here
You'll need to pull the logic board out to gain access to the screws which hold the Port assembly and/or access the springs. Now if they have snapped then you will need a new case assembly unless you can find a junker to steal them from it. Here's the guide MacBook Pro 15" Touch Bar 2017 Logic Board Replacement
Replace one of the thunderbolt connector boards from the left or right side of your laptop. 이미지
제품
$19.99
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you so much
@can_of_bread - Happy fixing!
I am just seeing this answer as my Macbook Pro 2017 2-Thunderbolt Ports (A1708) USB-C ports are causing my usb-C hub to disconnect at the slightest breath. I've tried cleaning the ports and the problem did not improve. This answer shows the board for the model with the Touchbar from the same year but mine does not have that. Do I need different parts or process? Please share! Of course would prefer an easier fix to keep the connection solid, but anything helps! Thanks.
댓글 달기
답변을 추가하세요
Stephen Syvertson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 46
전체 시간: 4,262
