주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A22 5G는 갤럭시 A 시리즈의 일부로 삼성전자에서 개발 및 제조한 중급 안드로이드 기반 스마트폰입니다. 이 휴대폰은 2021년 6월 24일에 처음 출시되었습니다. 이 전화기에는 트리플 후면 카메라 설정과 90 Hz 디스플레이가 함께 제공됩니다. 배터리는 5000 mAh로 iPhone 13 Pro의 배터리보다 62% 더 큽니다.
Fingerprint scanner not working
The button is working properly but the sensor is not working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 5개
It's f42 5g but it's not working but after restarting it's starts working for few minutes only.
의
Sensor not work button is ok
의
Fingerprint not working sencer
의
Please working my fingerprint option Please 🙏 😢 Please
의
Finger print not working
의
댓글 달기
답변 5개
가장 유용한 답변
@siddhantsen @gulfamkhan @fathimaraihana the very first thing you want to do, is to tell us what you all have tried to fix this. You have to determine if this is software or hardware related. A couple of common things to do, is to do a soft reset first. Then check for any software updates. Make sure you have the latest software for your phone. So go to your phone's settings menu, then look for the "software update" or "system update" option. If there is an update, download and install it. Next clear the cache and data of the fingerprint scanner app. You should also remove and then add your fingerprints once more. For more of all of this, check Samsung's advice on here
If none of this worked, you should consider replacing the fingerprint scanner. In the case of your phone the fingerprint scanner and the power button are combined. Since there are no guides on iFixit for this (yet) use something like this video to replace it. Remember that you need to purchase a proper replacement for your version of the A22 (SM-A226B, SM-A226B/DS, SM-A226B/DSN) to ensure compatibility. You can purchase those at many places online. Pick a vendor that meets your expectations.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
이미지 내용 보기:
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone fingerprint not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes is now working as manual
이 답변이 도움이 되었나요?
점수 0
댓글 달기
مشلكة لايوجد البصمة a22
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SIDDHANT SEN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 43
전체 시간: 3,005
