주요 콘텐츠로 건너뛰기
Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
92 질문 전체 보기
My iPhone 12 Pro got wet, how do I know which parts are bad?
My iPhone 12 Pro got wet a few months ago and stopped working, I'm getting sick of my old phone and want to repair my 12 Pro. How do I know which parts need to be replaced? Is it the screen? The battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
Initially it would be hard to know what has been affected. You would need to open the phone and inspect for any obvious damage and after cleaning the board check what is or is not happening.
After a few months of not being charged and with possible water damage, most probably the battery will need replacing anyway.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 12 Pro guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
%#*@, you're awesome, thank you! I have been wanting to learn more about repairs so I can do things myself instead of wasting my money at a repair shop. Maybe I will go get a free diagnostic on it and buy and install the parts myself.
댓글 달기
귀하의 답변을 추가하세요
Spencer Ross 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 160
