주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 10월에 출시된 14인치 MacBook Pro의 수리 안내서 및 분해 정보입니다. Apple이 설계한 M1 Pro 및 M1 Max SoC가 탑재되었습니다. 모델 A2442.
Messed up removing flex cable
이미지
I think I accidentally stripped off one of the metal connections when removing the flex cable on the logic board. Have I completely screwed this up?
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi
Thankfully it hasn’t completely messed up the board because all but one of the pads looks ok
The other pin(highlighted in the photo) might have been ripped
이미지
The connector that has fallen off is for battery data,but in order to fix this you will need to solder it back on ,as for the pad we think is ripped :do you have the connector the fell off?
If so can you upload some photos of the side that faces the Board so we can see if the pad went with it
If you don’t have good microsoldering experience you might not want to attempt this repair and It would be better to have it taken to a professional as it may require replacing the pad that fell off and reattaching the connector so that it’s secure
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Yep certainly not experienced enough, I’ll be taking this to get repaired thank you so much.
@Chris Grant (Lifeoverflow)
You’re most welcome!
Please let me know if there is anything else:-)
댓글 달기
답변을 추가하세요
Chris Grant (Lifeoverflow) 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 513
