주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note 9는 2020년 4월에 출시된 샤오미의 중급 스마트폰입니다. 6.53인치 IPS LCD 디스플레이, 48MP 후면 카메라, 후면 지문인식 센서, 5020mAh 배터리를 탑재했으며, MediaTek Helio G85로 구동됩니다.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
의
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
의
non of the above works i have tried power and volume+ button but it is not going on that
의
댓글 달기
답변 3개
가장 유용한 답변
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I've set it back to Factory mode multiple times, so this is not working.
의
댓글 달기
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michael Kastner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 34
전체 시간: 1,456
