주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가장 큰 UE 스피커
No longer powers on.
MegaBlast won’t turn on.
This speaker is about a year old, seen moderate use and has never exposed to water, extreme temperatures or shock.
I have tried:
  • Charging the speaker using various cables and adapters over a couple days.
  • Charging via the PowerUp dock for a couple hrs- dock indicates charge complete solid light (battery is fully charged‽)
  • Did a hard reset
I’m out of ideas… If anyone knows of a teardown or repair guide for this device they can link me, I guess my next troubleshooting steps are pull ‘er apart and check components and solder joints. Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
Speaker needs disabled, and battery replaced
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@rachelembleton replace the battery and use that for further troubleshooting if necessary. Right now it sounds like a bad battery. It may accept a charge but does not hold a charge. With a new battery you will at least have a known-well starting point for further troubleshooting.
There are no iFixit guides for the battery replacement yet. You will have to peacemeal it together by using something like this as well as this video
Also, if you need any help, or if you are stuck somewhere, you can always post pictures with your question so we can try and help you further with this.
기존 질문에 이미지 추가하기
Take lots of pictures and once you have your battery successfully changed, use this guide https://www.ifixit.com/Guide/new to create a guide. The iFixit community will appreciate it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rachel Embleton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 30
전체 시간: 1,869
