주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 13 7390은 2019년에 출시된 콤팩트하고 가벼운 노트북으로, 10세대 Intel Core 프로세서, 13.3인치 InfinityEdge 디스플레이(주로 4K UHD), 얇고 견고한 알루미늄 섀시가 특징입니다. 동급 제품 대비 강력한 성능, Wi-Fi 6, 2개의 썬더볼트 3 포트를 통한 강력한 연결성을 자랑합니다. 비평가들은 USB-C에 크게 의존하며 전통적인 USB-A 포트가 없다는 점을 지적합니다. 이 노트북은 비슷하지만 360도 접이식 디스플레이를 갖춘 XPS 13 7390 2-in-1 모델과 혼동하지 마세요.
Does not turn on?
My Dell XPS 13 7390 just one day stop turning on. Replace battery to see if that was the issue, and still does not turn on. Any suggestion what it could be. Thanks!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
Hi @vookim,
With the charger connected does the laptop indicate that the battery is charging?
의
No, I get no power. The laptop has a battery indicated button on there, when I press it, show no power too.
의
XPS13 9370 here, same problem
의
Hi, see below. Open the back, discount the SSD, the battery, and other simple connectors that you can easily,include the CMOS 3v battery.
Press the power for 20 seconds. And connect all battery last. It did power to me..
의
댓글 달기
답변 3개
가장 유용한 답변
@vookim
Was the replacement battery fully charged?
Have you tried a different compatible charger?
On the front of the laptop there is a battery light (not a button).
When you connect the charger the light should show white if the battery is charging or orange if it is using the battery i.e. no charger connected.
If there is no light at all it is either fully charged or the laptop is in sleep mode or off.
Have you tried holding the power button for >10 seconds to force turn off the laptop in case it is in sleep mode and not responding and then try turning it on?
If still no good then there's a problem on the motherboard because it should show that the battery is charging even if the laptop is off. If the battery was fully charged the light would blink briefly when the charger is connected and then go out.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
How to Fix a Dell Laptop That's Not Working
Here are some steps for troubleshooting a Dell that won't turn on, from the most straightforward and most apparent to more advanced fixes:
Check the power supply. If none of the lights on your PC turn on when you press the power button, even when it's plugged into the wall, then you likely need to replace the power supply. Even if the charging light comes on when you plug in your computer, the cable could still be damaged, so check the power supply unit with a multimeter if you have one.
Remove any USB storage devices. Your computer could be trying to boot from the wrong drive. If this fixes the problem, change the boot order to ensure your hard drive is at the top of the list.
Power cycle your Dell laptop. With the computer turned off and unplugged, remove any external devices (USB drives, printers, etc.), then hold down the power button for 15-20 seconds. It will drain any residual power. Next, reconnect the charger and see if your PC powers on.
Remove the battery. If the charging light comes on, but your PC still won't turn on at all, there could be a problem with the battery. Newer Dell laptops don't have a removable battery, but you can replace them yourself if yours does.
Regards,
Will
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I tried all of the steps you listed and no light comes on…. I have an XPS 13 9370. It won’t turn on with AC or battery.
Replaced charging cable and battery, still nothing. No lights, nothing. Help!!!
의
The 15/20 seconds button push helped me. XPS 15 Dell
의
Your 15-20 sec power cycle worked for my xps 17. Should I be concerned about this happening again. I checked and it is 100% charged. What caused this?
의
Many thanks. I did exactly as you said, and id did power on!!
Just removing the battery didn't help.
의
댓글 달기
It can be the issues of power lort
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Voo Kim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 47
전체 시간: 13,789
