주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sega CD Model 2는 Sega Genesis II의 업데이트된 디자인에 맞춰 1993년에 출시된 Sega CD의 개정 모델입니다.
CD drive not spinning
ive found that my sega cd is not reading disks ive had the unit apart and found that the laser will attempt to find the disk but the motor wont spin the caps on the board appear to be fine as do the other components i have attempted to clean the lens to no avail and suggestions as the what the problem could be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Carter Logan make sure that the nylon gears on the the sled drive are in good working order and do not have any broken teeth etc. Make sure they mesh. You also want to check for power on the motor. After that I suggest you check the schematics and measure the caps etc. After all, things are getting a bit weak after 30 years :-) and recapping might just be on order. Use this manual Sega CDto help you with working on your console.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
motor is getting proper voltage and gears are fine im thinking the laser is bad ive read that the motor wont spin if the laser cant find a disk
의
@Carter Logan time to replace it
의
댓글 달기
Hi, did you ever find a fix for this?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Carter Logan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 49
전체 시간: 2,204
