주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 A1367 / 8, 16, 32 또는 64 GB 용량
Why is there a box around everything I click?
Every time I click something, a black box pops up around it and it is very anoying.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 42
댓글 15개
It won't work
Its Driving me FRIGGIN LOOH LAAAH!!!!! Trying to fix it for 2 hours now, had problem also with someone constantly reading text and app covers on home screen non stop over 50+ Apps, reading them @ 90mph lol. Now just left with this stupid box!!! I have actually changed so many settings by accident on the phone cos the box has a mind of its own bouncing all over the screen, that if I do fix it , I wont know What's what n b like F*** where is everythin ????
Thank you! I went to General, then to accessibility and last to "Voice Over". Turn off and turn back on... This is how I fixed the annoying blue box and clicks. Thanks for the tip.
i have this problem too! i turned it off, and turned it back on. now it won't let me put in the password. help!
Well i cant actually get into my phone because its on activation lock and i know my apple id email but i dont know the password so whenever i go to reset it i cant because it ask for the old phone number of that phone but i dont know it.
댓글 10개 더보기
댓글 달기
답변 7개
선택된 해법
Sara, it sounds to me like you have your Voiceover on "When an item on the screen is selected, a black rectangle called the VoiceOver Cursor appears around it. The VoiceOver Cursor is displayed for the benefit of sighted users with whom you may be sharing your iPod touch. " Turn VoiceOver on or off: Go to Settings > General > Accessibility > VoiceOver. Download the manual from here starting on page 119 it will tell you all about it. Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 24
댓글 26개:
I REALLY HOPE this works. I have the same problem, thanks in adavance
I can't scroll tho
I can't scroll down
thanks very much ey...it worked on my Ipad
댓글 21개 더보기
댓글 달기
가장 유용한 답변
Hit the home button 3 times... it will work!
이 답변이 도움이 되었나요?
점수 31
댓글 16개:
perfect! thanks
thx very very mutch
Thank you so much for the help
Worked straight away - thanks for your help :)
thank you so much!!!!!
댓글 11개 더보기
댓글 달기
Ask Siri to turn off voice over. It worked for me.
이 답변이 도움이 되었나요?
점수 5
댓글 9개:
I have iPhone 4 I phone 4 doesn't have sir
or does it
I dunno
my siri is not listening very well
what do I do now!!!!!!??????!!!??!?????
Sir I is not responding
I have an iPhone x. This worked. Say, "Hey Siri" then "Go to Voice Over". You'll be able to turn it off even if your screen doesn't allow you to by saying "Turn Off Voice Over". Immediately able to touch my screen again without the glitches or annoying boxes surrounding every little thing on the screen that I touch. You can try double tapping the item but mine didn't always work.
댓글 4개 더보기
댓글 달기
Hold your home but ten for three long holds
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
what home grace
I found my pld ipod mini. Hiw do i fix that?
Not sure but try holding home button and on off bottom at the same time for 30 second
댓글 달기
Like the other answers, pressing the home button thrice worked! My friend lent me his iPad and I let my cousin play the iPad. After, she left it on the drawer. I checked it and it does not work! It illuminates the screen but nothing shows up. But then I saw an answer that said to tap the screen with three fingers and it turned on "'BUT"' whenever I tap anything it squares the tapped thing. So the technique worked! I am thankful to the others who helped me since it saved me from getting grounded "'AND"' getting fined as well.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It just keep asking for password code for siri but when I type a code it doesn't work
Hmm thrice!
Juliet is the sun.
Arise fair sun and kill the envious moon
댓글 달기
Just hold down button for Siri and say, "Siri, turn off "Voice over in settings". My phone was instantly restored and back to normal.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Worked on the first try with Siri assist.
댓글 달기
I have an LG and it has a voice to it and there a green box over when I hit everthing and it wont let me swipe. or nothing how do I make it go away????
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sara 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 47
전체 시간: 168,096
