주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
클래식 Xbox 무선 컨트롤러의 세 번째 개정판은 2020년 11월에 출시되었으며, Xbox Series X 및 Series S와 함께 제공되었습니다. 이 컨트롤러는 이전 Xbox One 게임기와 PC에서 하위 호환됩니다.
Problem with LT and RT always pressed
The left and right trigger always keep pressed, this problem began when i replace(
solder and desolder) both stick, first right stick and the controller works normally but when i replace the left stick the problem began.
This video show better the problem(this is the official xbox app): https://1drv.ms/v/s!AhpypwlrW5KohIBgdkgz... as you see the lt and rt button keeps pressed but the others works normally and this is another video with other app(the problem is more visible with this): https://1drv.ms/v/s!AhpypwlrW5KohIBhcMTA...
Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
가장 유용한 답변
I just came across this problem on LT and fixed the problem by replacing the U11 component (303 hall effect sensor for the trigger) with an old xbox one controller 304 hall effect sensor.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Just wanted to say thank you for this! I didn’t need to replace it but reflowing this chip fixed the issue for me! I wouldn’t have even known to touch this component had it not been for your comment.
의 공유
@stuffmonster I'm glad I was able to help someone with this solution. One less controller in the bin. 😎
Thank you!
의 공유
댓글 달기
Check U9 controller on a board. On output should be 1.4V. I have a solution but it's not very nice. Connect output trace with 3.3V. It worked for me but I don't guarantee that it will work for a long time. You could also replace this IC. Problem is that it's a very small piece and it is easy to burn using hotait. Sometimes this IC doesn't have any specifications on it (especially in 1708 and older) so proper resoldering it can be quite tough
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
do you mean inject voltage on the trace to fix it?
의 공유
Yes. It helped. I don't remember where specifically I connected it, it was a long time ago. Maybe before a voltage divisor if there was. I remember that those sensors have common power so if there is no power, they both don't work.
의 공유
댓글 달기
WERE you able to fix it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If anyone encounter problem with LT and RT trigger always pressed, replace U9 controller, for me it worked, and I even used U9 chip from Xbox One controller and soldered into Xbox Series Controller and yes it worked if someone was wondering.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rafaeljevi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 52
지난 30일: 211
전체 시간: 5,725
