주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Western Digital의 WD Elements Desktop USB 외장 하드 드라이브 제품군에 대한 수리 및 서비스 정보입니다. 3TB, 4TB, 6TB, 8TB, 10TB, 12TB 및 14TB 구성으로 제공됩니다.
Power adapter replacement for external WD
Hi guys,
I lost my original power adapter 12V 1800mA 18Watts for external WD. I have another from older WD but its 12V and only 1500mA and if I connect this it's not working. Than I have some 12V 3000mA - it's from LCD screen - can I use it or it's too much and I should stick with 1800mA ?
Thanks a lot for any ideas/advice.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @roboscrap
The device will only use as much current as it needs to, to operate.
As long as the voltage is the specified value i.e. 12V then using a 12V 3000mA adapter won't be a problem.
The problem with using the 1500mA adapter was that it couldn't supply enough current.
As you didn't specify the model I'm assuming that it uses an adapter with a centre pin +ve output connection as this is the most common connection.
If the adapter has a centre -ve pin output connection it will damage the HDD electronics.
The polarity of the output should be shown on the adapter case.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Center is +ve so I am good to go. Thank you very much.
의 공유
UPDATE - IF YOU DON'T CONNECT your external WD HDD to the USB/FireWire - it will not start up :D
의 공유
@roboscrap
Probably because standard USB ports only provide max of 500mA @ 5V
Firewire provides max 1500mA @ 8V - 30V
의 공유
@jayeff thanks for info :)
의 공유
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 55
전체 시간: 1,802
