주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10월 13일에 발표되어 10월 23일에 출시된 Apple의 2020년 플래그십 스마트폰은 6.1인치 OLED 디스플레이, LiDAR가 탑재된 트리플 렌즈 후면 카메라 시스템, 5G가 특징입니다. iPhone 11 Pro의 후속작입니다.
What else could be wrong with my iPhone 12 Pro?
이미지
My phone got smacked by an ATV after it fell out of my pocket. I don't think it was actually run over b/c the damage doesn't look that bad.
However the screen is smashed and it won't turn on. I opened it up and it looks pretty good... the battery doesn't looked smushed or bulging.
So I bought a replacement screen because I really just want to get it to turn on so I can get the photos from the day it died. But I plugged in the screen and it still doesn't power up.
I was thinking that maybe some other parts I can't see are damaged, but before I completely disassemble it, wondered if anyone has some other things to check.
thx
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 6개
Did you disconnect the battery before you changed the screen?
What does the back of the phone look like?
@barriphone i dont think it matters now in newer models if you disconnect the battery before replacing the screen
@guardian10 im doing more consoles than phones atm so havent looked into it much
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
Yikes, I think I disagree as to whether it got run over or not, lol. That's one broke phone!
Anyway, check the charging port carefully with a magnifying glass and a bright light; there could easily be dirt or debris in there keeping the plug from making good contact. You might try cleaning it with a microfiber eyeglass cloth and some 90% or higher isopropyl alcohol; a toothpick works pretty good for getting the cloth down into the port.
Once you're satisfied the port looks good (and has no bent or broken pins), try plugging it into a computer and see if it's recognized. That will tell you if it's got a minimal amount of function even if you can't see anything on the screen.
Give those things a shot and let us know what you find.
이 답변이 도움이 되었나요?
점수 4
댓글 20개:
Good job bro I like you’re Answers
Ps I voted you up 😁
splatkat, I think I have to agree with @dadibrokeit’s disagreement; That looks like it was both hit and run over. The funny thing: It’s actually worse for the phone to get “smacked” hard, than to be run over by a tyre, because the impact can result in forces many times greater than a tyre running over it.
If what @dadibrokeit doesn’t show any difference, you could likely be looking at board separation :( That will require splitting the logic board and further analysis.
thanks @dadibrokeit.
so, i did clean out the charging port as suggested and plugged it into my computer, but nothing happened.
however, i did the same thing with another iphone and before my computer would recognize it, i had to put in the passcode to unlock it and use the "accessory" (i have the phone cable plugged into a USB hub since my macbook only has USB-C ports and my phone cable is USB 2.0 or whatever) ... so since the screen on this broken phone isn't working, i won't be able to unlock it so that the computer can see it.
@geirandersen tire* not tyre sorry for being rude just letting you know 😁
댓글 15개 더보기
댓글 달기
Maybe the battery got dislodged and there is a way to get the info of off the phone I think search it up
Maybe some part or components got smashed this happens trace the board and tell me what you see (might need to use microscope)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
Camara 1x .5 not working
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What do you mean by not working? Please give us more detail if you want an answer.
댓글 달기
답변을 추가하세요
splatkat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 25
전체 시간: 771
