주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2005년 11월 22일에 출시된 Xbox 360 무선 컨트롤러는 Microsoft의 Xbox 360 가정용 게임기 전용 주요 게임 컨트롤러입니다.
Battery board has rust and doesn't work
So I recently found out that my 360 controller is very rusty on the back and especially on the battery board and it just won't turn on anymore like the old days. Any help is highly appreciated. Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @stroft2
"Rusty" sounds like a battery may have leaked and corroded the battery connection terminals or water has penetrated the controller at one time and done the same.
Remove the battery from the controller and then disassemble the controller and clean the terminals (and anything else) using a Q-Tip slightly moistened (not dripping) with Isopropyl Alcohol 99%+ (available at electronics parts stores).
Once the terminals are bright and clean (if there's any left that hasn't been corroded away) re-assemble and insert a new battery and check if it works OK.
Here's the Xbox 360 무선 컨트롤러 하단 패널 교체 guide that may help.
Here's the rest of the controller repair guides if you have to disassemble it further. Xbox 360 Wireless Controller
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
stroft2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 42
전체 시간: 3,106
