주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fisher&Paykel에서 출시한 통돌이 세탁기입니다.
Not completing spin cycle
machine seems unbalanced no matter how often I re arrange the contents. It stops on rinse and beeps, and won’t move forward- progress- with the cycle. Happens more often than not recently.
Unsure why is now unbalanced. Machine is one of the earlier ones (low agitator)
Update (12/19/2022)
F&p Aquasmart WL70T60D 92127-A-NZ
Aso during the rinse and spin it thumps and bashes around really badly before stopping and beeping and the rinse light stays on, or if I progress it to spin does the same until it stops with the spin light on - and the clothes are still wet.
Been doing it for the past 4 washes perhaps.
I have done two auto tub cleans
I have replaced the straps that attach in the four corners but hasn't helped
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Hi,
Not sure re the model but check if the suspension rods are still attached OK. These are what the straps that you replaced are connected to.
I couldn't find a service manual for your model but I think that this service manual for a comparable USA model might be very close. Run the diagnostics as shown on p.38 to see what error codes if any are shown.
Also here's the parts list for the AU model which may help if you need parts. Search online using the part number to find suppliers.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Suspension rods worn out
The straps dont do much
의 공유
댓글 달기
Fixed previously - found some used but not too used suspension rods and that worked.
Had already bought and installed new straps.
I had much fun? using jeffs pdf manual and stripping down then cleaning the everything - including waterblasting the bowl and cleaning out the flapper.
All 100% now
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
The suspension rods are springs in this model, no oil like others. If you replaced the rods and it worked, doe that mean the springs or rod itself wear out too? We are doing a deep clean now, and have also replaced the suspension straps. It works much better with new straps, as one was busted. But is still unbalanced at least once or twice a wash.
의 공유
댓글 달기
답변을 추가하세요
robyn.holmes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 68
전체 시간: 3,973
