주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson AM10 가습기에 대한 수리 및 분해 정보입니다.
What does a Piezo do?
My AM10 has stopped misting, doesn't draw any water from the tank.
I am trying to troubleshoot it.
First stop is something called a PIezo, which is accessed from a panel on the bottom of the base unit.
my looks to be in poor condition but I don't know if it is the source of the problem. in fact I don't even know what it does.
it appears to have a watertight seal. so it must be sitting at the bottom of the water tray.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
@pjstock, A piezo is basically a “speaker” or more commonly known as a buzzer.
I say “speaker” because because it’s not playing sounds as a speaker, it’s only really capable of producing tones in given ranges.
You can Google “piezo buzzer” if you want to read and understand more about it :)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Google it. Loads of different types.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi. I have the same issue with my am10. Have you found a solution?
Thanks! I’d appreciate it!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
change it will help. I also have the same problem and find it in amazon https://www.amazon.com/dp/B0BWN3BZR8
의
댓글 달기
I think in this device working the piezo element not like speaker but like object size detector. Same like in dyson vacuum cleaner. Small pieces hitting the piezo, thats generate a very small current, from this currend is calculated how many and how big pieces was catched.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same issue . No mist anymore . I changed the piezo but it did not help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
peter stock 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 37
전체 시간: 1,648
