주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A72는 2021년 3월에 출시된 중급 USB-C 스마트폰입니다. 90Hz Super AMOLED 스크린, Snapdragon 720G 칩셋 및 6-8GB RAM을 제공합니다.
Why is my screen Unresponsive
the device is unresponsive to touch, after a hard reset it becomes responsive but only lasts for +- 5 minutes, I did a factory reset, and it worked for yet another 5 minutes, managed to update it to the latest software but still becomes unresponsive. Has anyone experienced this before? I keep seeing guys on youtube do a hard reset then claim it's permanently solved and others changed the main Flexi cable also claiming that the Flexi is faulty from the factory. Any advice on flexi cable solution?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 1개
선택된 해법
Ulrich Elikana the only way to check on that flex issue would be by checking the connector and the cable (properly seated, tears etc.) itself first. After that you could try a new touchscreen which will have a new flex cable. If that does not resolve it, the issue could come from the IC on the circuit board. That would require some boardlevel repair knowledge, schematics and component placement chart etc.
이 답변이 도움이 되었나요?
점수 3
댓글 9개:
IC as in the board that holds the charging port etc? main board flex connects to it aswell. Took it to phone repair once the dude , mentioned that connections are clean aswell as flex cable.
의
@Ulrich Elikana let me double check with IC is responsible for the touch and if there are other components that we could test for proper function. I know there were issue with the flex and its connectors not properly making contact.
의
Ok.Thanks will be waiting for your feedback,
의
@Ulrich Elikana This does look like a Flex cable issue. It appears that this is a very common failure. I'd replace the LCD Display Main Motherboard Connect Flex Cable. something like this should work.
의
@oldturkey03 Thank you very much, I've placed my order for the flex cable and will give you feedback aswell, expecting it around the first week of March.
의
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Ulrich Elikana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 48
전체 시간: 3,634
