주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Intellivision은 1979년 Mattel에서 출시한 게임기입니다.
Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
Did I spell Intellivision correctly?
의
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
의
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
의
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
의
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
의
댓글 1개 더보기
댓글 달기
답변 1개
선택된 해법
Hello, check this from the service manual:
1. Connect the Master Component to TV, plug in power cord, set the Antenna Switch Box to TV and determine that the set works correctly on broadcast stations.
So, make sure that your switch box is set properly.
UPDATE
Here is a link to an online service manual that can further help you narrow things down.
이 답변이 도움이 되었나요?
점수 3
댓글 14개:
Sorry, I didn't know what a switch box was. Do you know where I can get one?
의
This will explain some more http://www.atariage.com/howto/connect.ht... and your best bet would be to try Google to get a switch box. They are still around but hard to find. Not knowing where you are, you might want to try Radio shack as well.
의
Thanks, I found it on AtariAge, and the adaptor is at RadioShack for $4.19. I will buy it tommorow and see how it works and tell you guys. Thanks oldturkey03!
의
Sounds great, good luck to you. Hope it works out and let us know....
의
Unfortunately, it didn't work out. But, I've found the culprit! It's the power supply. It was in the Intellivsion Service Manual. But, does anyone know where I can get one of these. I don't want to have to rebuild it(even though I know soldering pretty well).
의
댓글 9개 더보기
댓글 달기
답변을 추가하세요
thelectronicnub 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 30
전체 시간: 6,362
