주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pokemon Go 모바일 게임용 손목 밴드 액세서리입니다.
adhesive recommendation for re-assembly
i'm looking for an adhesive recommendation to re-assemble a repaired Gotcha Evolve. when i (very carefully) took it apart there was a bead of glue around the inner case perimeter (reminded me a lot of hot glue-gun glue). it was very tacky but very flexible. adhesion was good as it took a while to pry it off the base side.
i'd like to find something that
A) does a good job of holding the top and bottom together
B) would still enable the separation of top and bottom (using the same technique of a thin blade or spudger to pry them apart without breaking them, in case i need to do further repairs
C) keep it's form when dispensed, unlike liquid glue that would just flow everywhere (self-leveling i think is the correct term). if i put a seam of it down, i want it to hold that shape until i press the two pieces together.
any thoughts?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
T7000 or T8000, use it all the time on phones, tablets and watches etc.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
how is the viscosity? does it free flow (self-leveling)? or does it hold it's shape once out of the dispenser?
의
@beekerc it will level but not run. Stays where you put it. Good stuff. Think you can buy a 10ml tube if you don't need much.
의
@strongbow
will look into it. E6000 definitely levels and runs.
의
@beekerc T7000 is clear and T8000 is black. Also look at B7000 which is thicker.
의
will do. thanks
의
댓글 달기
Hi @beekerc
Try using Tesa 61395 Tape.
It works well on phones, so perhaps it is also suitable for your device.
Custom cut rolls of Tesa 61395 double-sided tape for repair. 이미지
제품
Tesa 61395 Tape
$8.95
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@jayeff
I've heard about Tesa Tape, but have not tried it as i too have been using the "red tape" which is good for holding things in place, but not really great for a "holding things together" application. i may give this a shot, i just hope it's thick enough. the bead/seam that was present after i had separated the top an bottom halves was a bead/seam of adhesive like had come out of a hot glue gun, if i had to guess at least 3/4 to 1mm i diameter.
Tesa tape or red tape may not be thick enough, although i could double stack. just don't know if the tesa tape adhesion will be strong enough.
but i'll look into it.
thanks
의
@beekerc
I've used it on a few phone display replacements I've done (for family, I'm not a professional) and there have been no comebacks yet ;-)
의
댓글 달기
답변을 추가하세요
B C 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 13
지난 30일: 28
전체 시간: 414
