주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chromebook Pixel의 정신적 계승자인 Google Pixelbook은 2017년 Made by Google 행사에서 공개되었으며 2017년 10월 31일에 출시되었습니다. 모델 번호: C0A.
How to repair Pixelbook wireless
Google says it's outside the warranty period and it's a wireless hardware issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi @sabinagmail
What is the problem with the WiFi?
If it is turning on but not connecting to a network, then it may be an antenna problem, loose or disconnected perhaps. Try using the laptop as close as possible to the network router e.g. <10cm, and check if the WiFi works OK.
If it does, here's the ifixit Google Pixelbook 마더보드 교체 guide. At Step.24, the antennas can be seen being disconnected from the WiFi card.
If there are other problems with the WiFi and you've proven that it is a hardware problem and not a software problem (powerwash?), the WiFi module (Intel 7265D2G) is soldered onto the motherboard so it won't be easy to remove.
Searching online for a replacement WiFi card produced no results.
Unfortunately I was also unable to find any USB-C WiFi dongles that you could use to connect to the laptop so that you could have WiFi capability again.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you! Will try it.
의
댓글 달기
답변을 추가하세요
Sabina 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 650
