주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-30Xa 공학용 계산기 수리 및 문제해결.
Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
의
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
의
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Texas Instruments TI-30Xa 분해도 guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Papaya Bear 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 579
