주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
16GB, 32GB 또는 64GB 저장 용량으로 제공되는 CDMA 3G 셀룰러 네트워킹(Verizon) 기능의 2세대 Apple iPad에 대한 수리 안내서, 분해 및 문제해결 정보입니다. 듀얼 코어 A5 프로세서가 탑재되어 있습니다. 2011년 3월에 출시되었습니다. 모델 번호 A1397로 식별할 수 있습니다. 수리 시 열을 가하고 조심스럽게 들어내는 작업이 필요합니다.
Transfer Data From Dead Logic Board?
Hi all,
This is my first question, so please bear with me as I figure this out.
I have a iPad 2 CDMA (64GB) that had the battery swell up and explode (no one was injured other then the iPad itself), and it killed the screen, case, and the logic board. I bought the same model on eBay to try and swap the parts, and after I tested individual components with the new ones, I know that the logic board is dead, although I did get a relevant current draw when the power button is pressed. .
Since I know the logic board is dead, I used the iPad 2 Teardown Guide to locate the NAND flash chips, and attempt to transfer them to the new logic board. The only issue is that I ripped a few PCB pads during the de-soldering process of the original chip on the new logic board.
Is it possible to fix the ripped traces, or do I need another new logic board? Also, is this idea to recover the data even feasible? Since I haven't touched the original logic board with the data yet, those chips are still soldered on, so I obviously need a few tips on removing those as well.
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
It's deceased, I wouldn't waste your time.
의
댓글 달기
답변 2개
선택된 해법
It's not possible to recover data this way by replacing just the NAND chips. The data on them are encrypted with keys only known to the CPU, you need to migrate the CPU onto a new board as well.
Fixing ripped pads under the NAND chips or on the board is possible.
https://www.bilibili.com/video/BV1Ci4y1R...
https://www.bilibili.com/video/BV1vW411C...
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Great, Thanks! One more thing though. Do you have any tips with the hot air station so this doesn’t happen again? My previous settings were 400C at 50% blower speed. That seemed to be the minimum to get the chip to come off, so I must not be doing something correctly.
의
댓글 달기
I think I got it, but now the iPad is boot-looping. Any suggestions? Thanks.
Edit: I just left the iPad sitting there for an hour or so, and it finally booted up. Thanks for the help!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
archaic_fixer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 52
전체 시간: 1,656
