주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Transformer Pad TF300T는 2012년 4월에 출시된 Android 태블릿 컴퓨터입니다. Asus Transformer 디자인에는 태블릿을 노트북 컴퓨터처럼 '변환'해 주는 옵션형 도킹 키보드가 포함되어 있습니다.
Main charging ports have failed
After some time mine has stopped recharging and has gone flat.
The charger and cable seems fine when checking with a multimeter
When connected with the dock/keyboard it does not charge
When not connected with the dock/keyboard it does not charge
At no time do I recall any sign or smell of burning
How can I charge my TF-300 for further investigation into fixing?
Is there any way to charge my TF-300 through the USB-1 port? Like I have seen other devices charging through a USB-3 port?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@fuzzoffury according to the manual you can. "Charging through the USB port may take a longer time to complete. If your computer does not provide enough power for charging the ASUS Transformer Pad, use the wall outlet instead" Time to repair your charging ports :-)
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
There seems to be a misunderstanding
Can I charge into the usb-1 port on the opposite side from the port usually used for charging on the dock/keyboard?
No matter where the power is charging from?
@fuzzoffury Your computer commonly only supplies around 500mA on the USB port which may not be enough to charge the tablet.
댓글 달기
답변을 추가하세요
Mark Rienits 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 277
