주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ThinkPad T450은 5세대 인텔 프로세서를 탑재한 가볍고 견고한 14형 비즈니스 노트북입니다. 이 기기는 2015년에 출시되었습니다.
No Power to Display
The computer powers on and I can hear the (very loud) chime when Windows is done loading but there’s no video on the built in display even after replacing the LCD assembly (it appeared to include the backlight board with the panel). It is usually used with an external monitor as the previous panel wasn’t working either. PC laptops are a little outside my knowledge, but I am very well-versed in Apple repairs. In Apple terms I want to reset the SMC (system management controller) but I don’t know how to do that on a Thinkpad. Does anyone know or have additional ideas? (I have tried the Microsoft troubleshooting steps for no video and they did not resolve the issue.)
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @jsnelson.
Did you have the battery disconnected from the motherboard just prior to removing/replacing the LCD panel?
When the laptop is on, try shining a flashlight at an angle close to the screen and check if you can detect any images. They will be very faint if they are there, so trying in a darkened room may help to see them.
If there are no images to be seen and you've replaced the LCD panel and since an external monitor works OK it may be a problem with the LCD cable (loose connection?)
If there are images then it is a backlight problem.
The backlight voltage supply is always supplied to the display and the backlights are turned on and off in the LCD panel by a signal sent on the backlight enable lead (Backlight on). This signal is controlled by the IO chipset (BIOS) and can be caused by events such as the lid closing/opening, screen timeout settings, external monitor display only selected etc.
Check fuse F7 (type 3A_32V_ERBRD3R00X) on the motherboard is OK and not blown
이미지
(click on image)
I searched for AIVLO NM-A251 REV 1.0 as searching online this seemed to be the board number for the motherboard (printed on the board itself)
Hopefully a start
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jsnelson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 32
전체 시간: 721
