Keyboard ribbon cable and speaker
The tablet speaker was not working.While opening the back cover for checking the speaker, the keyboard ribbon cable came off at both ends from both the connectors.Now I am not sure about the orientation of the flat cable.Contact side facing down in the mother board connector? Also what should be the orientation in the back cover connector?
Also please inform me the specifications of the speaker like watts,ohm etc.,for replacement as I am in India.
좋은 질문입니까?
댓글 2개
Hi @shanks51,
Please verify the make and model number of your device.
The device you selected doesn't have a separate keyboard, unless you meant the digitizer screen.
jayeff 의 공유
Hi @jayeff,
It is an RCA Tablet.Model RCT6203W46 which is having a detachable keyboard folio.As mentioned in my OP since the ribbon cable needs to be replaced,I need confirmation regarding contacts' side orientation.
I have to buy the speaker locally in India and I need speaker technical details also.
Thanks.
Sankaranarayanan Swaminathan 의 공유
