How do I replace ink cartridge?
Black ink is running low and not sure how to get to it to replace it?
좋은 질문입니까?
좋은 질문입니까?
This is a termal printer, it does not use ink or toner, chances are your battery needs charging or replacing.
이 답변이 도움이 되었나요?
Why do I need a battery for the thermal printer if it has an electrical plug?
@gailstewart You are correct that the LabelWriter series are all corded. Are you having the same problem as the original question, of the printing fading out?
지난 24시간: 4
지난 7일: 16
지난 30일: 49
전체 시간: 2,598
댓글 3개
Hi @keithpl,
Please verify the make and model number of the device that your question is about.
The Dymo LabelWriter 450 doesn't use ink. It is a thermal printer. The printer uses heat from a thermal print head to print on specially treated, heat-sensitive labels
jayeff 의 공유
I have a Dymo LabelWriter 400 Turbo, do I need to replace the ink cartridge or is there no ink on this model too?
Brenda 의 공유
@brenda27832
All 400 series Dymo LabelWriters are the thermal print type i.e. no ink
jayeff 의 공유
