주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
Activation lock on phone
I got an iPhone 11 online from someone who was selling it, I didn’t know there was an activation lock until I went to set it up, I can’t get in contact with the person to remove their Apple ID, is there any way I can remove it so I can continue to use it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
Nope, short of changing the motherboard and all of the tied components, that phone will never be removed from the iCloud account if the owner does not remove it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
like Woah says, you will need to contact the previous owner and have them login to the icloud account and remove the association, either on the phone itself, or via either www.icloud.com or appleid.apple.com.
beyond that there is no permanent solution.
yes, you will find services and software offering to remove icloud accounts, it's all BS. these "solutions" involve jailbreaking the phone then installing a "bypass". but the phone will not behave like a normal phone (if i'm misstating some of these items, i welcome correction as a am not a jailbreaking expert). you will likely have issues with downloading and installing apps, you may have issues trying to use the only on you cellular service account, you cannot do auto upgrades the IOS, your device becomes more vulnerable to malware/hacking, battery drain/usage increases dramatically, it makes the overall IOS environment less stable meaning more crashes, and if you do upgrade the IOS or reset the phone, you have to re-jailbreak it again.
using jailbreaking to "fix" an icloud account is like (you may be too young to actually relate to this) watching TV before they had remote controls. you want to change the channel or change the volume or adjust the rabbit ears, you had to get out out of your chair, walk to the tv and do so manually - every time. sure it all worked, but it was horribly inconvenient compared to what a modern day TV remote can do for you.
if anyone has a better analogy, i welcome input on that regard as well. :)
bottom line, the only way to properly remove it is to have the icloud account owner do it
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
But, what if it is my phone?
Because, ever since I installed the latest update, I got the black screen of death and I can't finish the restore BECAUSE I CAN'T SEE THE SCREEN! So I cannot activate! Now what?
댓글 달기
No, only the person that the account is locked to can remove it. Sounds like you've bought a found or stolen phone. Not even any good for parts.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
April 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 254
