주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Coolpad 3300A는 Coolpad Group Limited에서 제조한 보급형 스마트폰입니다. Coolpad 3300A는 2015년에 150달러 미만의 가격으로 출시되었습니다.
How to remove the Daughter board?
My charging port seems to have problem with the charger cord. Can I replace the charger port on the Model 3622 a ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
I noticed that this is a different model from the one I have which is a 3622A not a 3300A
Thanks but the problem I have with the Coolpad model 3622A is that the screen cannot be removed once you separate the rest of the phone from the screen.
댓글 달기
답변 1개
가장 유용한 답변
@machanik yes you can. This is the part you need. Follow something this video to get to the board.
Update (03/02/2023)
@machanik yes you are right. Like I said that video will get you to the board. Then you have to remove the flex cables and remove the screws to remove the board. It is actually pretty easy once you are on the inside. If you get stuck on that, post some good pictures of your board, when you have your Coolpad open. That way we can guide you all the way. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
hanks but this video was not the one I'm looking for to remove the daughter board.
The model I have is a 3622A. The one feature here is a 3300A.
@machanik here is one for the 3622A. Same principle.
댓글 달기
답변을 추가하세요
Phill Comeaux 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 25
전체 시간: 380
