주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Lenovo K 시리즈 데스크탑 모델인 K410은 3단계 속도 조절 전원 스위치와 3세대 Intel Core 프로세서를 탑재하고 있습니다. 뛰어난 그래픽 성능 덕분에 게임용으로 탁월한 선택입니다.
Drive Is missing from computer.
I keep getting a message saying that my E drive (history) is missing. WHAT can I do to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @psmuafcjnsvkuvb
Check in BIOS to see if the HDD is being detected by the BIOS in the connected drives list.
If not turn off the PC and disconnect the power from the PSU and then open the case and check that the E: drive is still connected OK to the motherboard, both the power cable and the sata cable.
If all appears to be OK then reconnect the power to the PSU and turn on the PC and when it has booted etc, check if you can feel if the E: drive is spinning (if it's a HDD and not an SSD that is).
If not it's either a power supply problem to the drive (try a different compatible power cable in the PC) or a power supply problem in the drive itself. Check that the drive's power cable is securely connected
If it is spinning then it's either a problem with the sata port for the drive on the motherboard (try reseating the cable both ends, motherboard and drive or try another sata port, do this with the PC off and the power disconnected!) or a problem with the drive's sata interface.
Hopefully not, but the drive may have failed.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
mzdaniels50 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 247
