주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 9월 21일에 출시된 셀룰러 연결 옵션을 포함한 Apple의 4세대 스마트워치입니다.
What is this part for?
I’m 13 years old and trying to take responsibility for breaking my Apple watch by fixing it myself.
I have the screen replacement, but this part came out of my watch. I think it is the force touch sensor, but I wanted to double check.
EDIT: My screen replacement is below. It is off-brand.
If possible could I get some help?
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If you review Step 8 in this Teardown of the Watch you’ll see the pictured part is not the ForceTouch sensor Apple Watch Series 4 분해도
As to what it is would be tough as there is not enough information in the image to gain a sense of scale or understanding the parts construction.
Using the teardown can you see what it is.
Update (03/05/2023)
@ebp049x - OK, was out enjoying the day sorry for not piping up sooner.
The display assembly is made up of a collection of discrete elements the crystal glass, the touch plate, the OLED screen, the backplate which holds the NFC chip.
What I see is a bunch of mangled parts and you still have part of the display assembly attached to the watches body.
You will need to get a new display assembly to fix this. Here’s the guide which also has the parts info Apple Watch Series 4 스크린 교체
Apple Watch Series 4 이미지
안내서
난이도:
조정
Apple Watch Series 4 스크린 이미지
안내서
난이도:
어려움
1 - 2 hours
이 답변이 도움이 되었나요?
점수 0
댓글 7개:
It is part of the screen, which is not disassembled in the teardown.
That's the touch screen. Don't worry about it.
If I do not reapply it or do not purchase a replacement, will anything on the watch be affected?
@ebp049x That is already on the replacement screen. Nothing to worry about. Good luck with the repair.
I posted an update
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Eshaan Bhargav Patel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 24
전체 시간: 455
