주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 일본, 2015년 9월 북미에 출시된 Nintendo의 첫 번째 주요 3DS 모델 변경 버전입니다. 2015년형 3DS는 개선된 3D 성능, C-스틱, 새로운 내부 amiibo 지원, 새로운 트리거 버튼 세트를 도입했습니다.
Possible hinge warping when replacing screen lens
Hi, want to replace the screen lens but I'm not sure if using a hair dryer to loosen the old lens will cause the hinge to warp and break, what would be a good way to prevent this from happening, or will it be fine without any need for prevention.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
@bruceblack44051 hopefully your hair dryer does not get that hot. Anyhow, always keep it moving, don't blast all the hot air at one spot. The trick here is to create an even warm area to remove any adhesive etc. If you are still concerned, cover the hinge area with some aluminum foil and you should be okay ;-)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I'll set the dryer to a lower setting when I use it to he sure, and thanks for your response appreciate it 👊🏼
댓글 달기
I am posting this to supplement the response @oldturkey03 left. There are a few hairdryers on the market to never, ever use for a case like this I have used on things like data recovery operations like an LG G4 509K, and Samsung as well as pre good design Pixel adhesive like the 3 XL: The Conair 1875. DO NOT USE IT, IT GETS THAT HOT. It will probably melt multiple parts if you're not careful! If it can get me into a P3/P4 series (known for terrible adhesive), it gets that hot. I won't even use it for battery adhesive unless I am replacing that battery; I seen all I needed to see after I pulled off a data recovery operation with a hairdryer... I don't want to know the risk level; it probably permanently compromised my old LG G4's battery since it had to be installed to turn on to the point I wouldn't even want to give it to a friend who knows I exposed it to that thing.
A good rule of thumb is if it's 1,000+ watts, probably too hot unless it's a "styler" design like the Conair 1875 styler. This is the bad one: Conair 1875, avoid; gets hot enough to melt solder, this is BAD FOR PLASTIC, but this one is fine: Conair 1875 Styler, less risky but be careful.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bruce Black 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 20
전체 시간: 538
