주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honda Fit은 Honda Jazz로도 판매되며, 2001년부터 Honda가 제조 및 판매하고 있는 5도어, 전방 엔진, 전륜 구동 B-세그먼트 소형차입니다. 현재 3세대 모델이 생산되고 있습니다. 전 세계적으로 판매되며 8개국 10개 공장에서 생산되고 있으며, 2013년 중반까지 약 500만 대가 판매되었습니다.
2012 Honda Fit - Engine Compartment Fuse Box
Does any other year and / or model Honda share a identical Engine Compartment Fuse Box with my 2012 Honda Fit? Mine has 3 fuses, a 100 A for Battery, a 70 A for EPS, and a 20 A for Horn/Hazard (turn signals). The 20A fuse is blown, I can't see any way to replace just that fuse. I don't want to cobble up a blade fuse, so my only choice is to replace the entire box. I'm retired, so I don't want to pay the dealer price, so you see that means u-pull-it, the reason for my question.
Can anyone help me out, please?
Thank you for any help,
Jim K
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @jimknowles
Have you checked if fuses 23 & 24 in the under dash fuse block are OK and are the correct rating, as they are fed by the blown 20A fuse that you want to replace?
They are both 10A fuses so by rights if there was a problem with the hazard lights (#23) or the stop lights/horn (#24), they should have blown and protected the fuse in the battery fuse block before it blew.
Don't know about how to remove it, but according to the 2012 Honda Fit service manual the fuses are not serviceable - see image below.
이미지
(click on image)
Try searching for 38210-TK6-003 and see if you can find one for a better price than what the dealer is asking.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jim Knowles 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 45
전체 시간: 1,428
