주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CB 라디오(모든 유형)는 1958년에 처음 도입되었습니다.
Radio Blowing a Fuse
Reposted for @matty77204:
I have a cb radio a COBRA 148F GTL am ssb with freq counter so it use to work i could plug it in and it work One day i got stupid and hook the power cord up to the 148F GTL and stuck the power cord into the power cord strip surge protector and it blew the fuse and i pulled the wires out a day later i replaced the fuse in the power cord and hook my cobra 148F GTL and it turn the radio on nothing but it blows the fuse in the line i then changed the fuse and hook my other COBRA 29 LTD bluetooth up it turns on off display works fully working so i was wondering if you know the cause of why my cobra 148F GTL wont turn on and when i turn it on it blows the fuse all the time.. Looking for answers. Thank you for your time... Matt
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
When you plugged it into the incorrect cord you shorted something on the circuit board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There will be a protection diode that has been blown by the (reverse polarity?). It will be a bit larger black resin type diode, and it will need to be changed out otherwise it will keep blowing fuses. A 4001 rectifier diode will work. Keep in mind the orientation of the original as far as anode and cathode. Now, with this said, I am unsure exactly what you plugged it into or what polarity. Hopefully it was a 12v power supply.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It will be very, very close to where the main positive wire runs into the circuit board from the power plug.
의
댓글 달기
답변을 추가하세요
Alex Diaz-Kokaisl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 26
전체 시간: 592
