주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips 58PUS8105/ 12 4K 앰비언트 라이트
Blank Screen- sound works.
Hi,
In need of some advice/ help and having read so many helpful questions, answers and solutions, I wanted to reach out to see if anyone has any idea.
The screen has suddenly gone blank, I’ve tinkered with a few TV’s over the past year or so, so I’m comfortable taking the TV apart etc.
Backlights are fully working so they’re not the issue.
Unplug 1 of the T-Con board Cables and half the screen displays as normal, plug that back in and repeat for the other T-Con board Cable and the other side of the screen works and displays what you would expect.
Clean T-Con Cables and their respective sockets, plug both back in and no image displayed.
Am I correct in assuming this is a Faulty T-Con board or is it likely the Video board is at fault?
Any help would be really helpful
Regards
Shep
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
i have the excactly the same issue. is it fixed with u in the meanwhile and if so what was the fix with u?
의
댓글 달기
답변 1개
@shep67506 according to your tests, I would start with the T-con board. Your main board is sending the right video signals to the T-con board For now the possibility of a bad main board would be pretty low on my list. If anything, it is something past the T-con board that would prevent your picture from displaying. T-con board first, Then re-evaluate.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 34
전체 시간: 1,367
