주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년형 총 출력 1000와트의 5.1채널 홈 시어터 시스템. 블루레이 플레이어, 내장 Wi-Fi, 간편한 음악 및 동영상 스트리밍을 위한 Bluetooth 연결을 포함합니다.
Micom Options are lost
My hometheater not working properly. I figure out micom Options are lost. All the op0, op1.. to op5 are 00. Is there anyone who has these codings. Of you have the device you can see the options through (NO DISC or Tray OPEN State) and Setup-DISPLAY-TV Aspect Ratio16:9 Full 4+5+6+2 +5+8+0 +ENTER
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @sercantaylan
Have you tried a power refresh?
Turn off the home theatre if it is on, disconnect the power to the home theatre and then press and hold the Power button for a full 30 seconds and then release it. Reconnect the power to the device, turn it on and check the settings
If no good, try contacting the LG customer service centre in your location (ask for tech support) and ask if the latest software version is available for your model home theatre, either as a download link or an emailed file
If they state that you can update online using the settings in the device (Settings > Others> Software > Update) tell them that there are no settings available and that you can't do this.
Also if there is software available ask how to install it manually.
Just what I'd try
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have updated but no change. I think the update doesn't make any change on eeprom :(
의 공유
댓글 달기
답변을 추가하세요
Sercan Taylan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 367
